Corsair Carbide Series Air 740 High Airflow ATX Cube Case
Key features
  • Design with dual chambers
  • Industrial-style ergonomics
  • Space-optimized internal design
Product codes
BIGGER IS BETTER
CORSAIR Carbide Series PC cases have the high-end features you need, and nothing you don’t. Designed to be the foundation of awesome, yet approachable PCs, they combine the latest case technologies and ergonomic innovations with amazing cooling potential, and plenty of room to build and expand.
Room to Breathe
The unique design of Carbide Series Air 740 utilizes dual chambers to deliver cooler air to your CPU, graphics cards, motherboard, and memory without your drives or power supply getting in the way.
Cool it your way
The included Air Series AF140L intake and exhaust fans deliver superior ventilation with less noise. The Air 740 features expansion room for advanced air cooling and water cooling setups.
Industrial-style ergonomics and space-optimized internal design
Offers massive internal volume by moving the power supply, SSD and optical drives into a separate chamber.
Expansion room
For up to six 120mm or five 140mm fans, a 240mm or 280mm top radiator, and a 240mm, 280mm, or 360mm radiator on the front panel.
Product Description Corsair Carbide Series Air 740 - mid tower - ATX
Product Type System cabinet
Form Factor Mid tower
Colour Black
I/O Connectors 2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards ATX, microATX, Mini-ITX
System Cabinet Features Windowed side panel, screwless drive bays, cable management holes, made of steel, supports 120/140/240/280/360 mm radiator in front panel, supports 120/140 mm radiator in rear, supports 120/140/240/280 mm radiator in top, supports 120/140/240/280 mm radiator in bottom
Power Device No power supply
Specification Compliance ATX
Dimensions (WxDxH) 42.6 cm x 34 cm x 51 cm
Weight 8.82 kg
Manufacturer Warranty 2 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Carbide Series...
