Corsair Carbide Series SPEC-03 BLUE LED Mid Tower Gaming Case
Key features
  • Huge side panel window
  • LED front intake fan, with room for more
  • Flexible cooling potential
  • Multiple drive bays
  • Easy system builds, maintenance and upgrades
Product codes
The SPEC-03 features an industrial, high-airflow front panel, a huge windowed side panel and a front 120mm LED fan. Add to that our USB 3.0 and native, tool-free SSD and HDD installation and you can have your killer gaming rig up and running in minutes.
Most cases at this price point don't give you the combination of great looks and great features that the SPEC-03 does. Up to dual 140mm front intake fan, an rear 120mm exhaust, and room for massive graphics cards makes the SPEC-03 stand out among the crowd.
  • Front - 2 x 140/120mm (1 x 120mm LED included)
  • Top - 2 x 120mm
  • Rear - 120mm (included)
  • Bottom - 120mm
  • 2 x USB 3.0 front ports with internal connector
  • Large side panel window
  • Cable routing and CPU cooler backplate motherboard cutouts
  • Seven PCIe slots with room for long graphics cards up to 426mm long
  • Install up to three 3.5" and two 2.5" drives simultaneously - tool free.
  • Dust filters for front and PSU intake
CORSAIR Carbide Series SPEC-03 - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Windowed side panel, screwless drive bays, front dust filter, CPU cut-out, cable management holes, supports 120 mm radiator in rear, PSU dust filters
No power supply
Specification Compliance
ATX
21.5 cm x 49.3 cm x 42.6 cm
5 kg
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Carbide Series...
