Corsair Cooling H115i Pro RGB 280mm Liquid
£141.61
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Customizable RGB backlit pump head produces vivid lighting effects to match your build
  • Two low-noise 140mm ML Series magnetic levitation PWM fans deliver improved airflow and produce just 20 dBA of noise at full speed
  • CORSAIR LINK software allows you to adjust RGB lighting, individual fan speeds, and pump speed while monitoring CPU and coolant temperatures, and more
  • The CORSAIR Hydro Series H115i PRO is an all-in-one RGB liquid CPU cooler with a 280mm radiator built for low-noise cooling performance and bold styling with an RGB LED pump head
  • Two 140mm ML Series magnetic levitation PWM fans provide great airflow while producing no more than 20 dBA of noise, pushing the performance of your build while staying whisper quiet
  • The CORSAIR Hydro Series H115i PRO all-in-one RGB liquid CPU cooler with a 280mm radiator built for low-noise cooling and bold styling with an RGB LED pump head
  • Zero RPM cooling profile in CORSAIR LINK software allows fans to stop entirely at low temperatures, eliminating fan noise
  • Stock Status: In Stock
Product codes
The CORSAIR Hydro Series H115i PRO is an all-in-one RGB liquid CPU cooler with a 280mm radiator built for low-noise cooling performance and bold styling with an RGB LED pump head. Two included 140mm ML Series magnetic levitation PWM fans provide great airflow while producing no more than 20 dBA of noise, pushing the performance of your build while staying whisper quiet. Take control with CORSAIR LINK software and customize lighting, monitor temperatures and precisely adjust fan speeds, or stop the cooling fans entirely with the H115i's Zero RPM fan mode. Easy to install and compatible with most modern CPU sockets, the H115i makes it easy to cool your system in silence and style.
Product Description CORSAIR Hydro Series H115i PRO Liquid CPU Cooler processor liquid cooling system
Product Type Processor liquid cooling system
Compatibility LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA2011-3 Socket, LGA1151 Socket, Socket AM4, LGA2066 Socket
Heatsink Material Aluminium with copper base
Fans Qty Dual
Fan Diameter 140 mm
Fan Bearing Magnetic bearing
Rotation Speed 1200 rpm
Air Flow 55.4 cfm
Noise Level 20.4 dBA
Features Pulse-width modulation (PWM) support, RGB LED
Dimensions (WxDxH) 31.5 cm x 2.9 cm x 14.3 cm
Weight 958 g
Features Corsair Link
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Cooling H115i...
£141.61
