Corsair Crystal Series 570X RGB ATX Mid Tower Case - Red
Key features
  • Four-panel tempered glass on every side of the case
  • Direct airflow path to keep your CPU and GPU running cooler
  • Room for practically anything
  • Cable management made simple
Product codes
With immaculate tempered glass enclosing the entire chassis, every component of your build is on display for all to see, including three vivid RGB LED fans and a built-in LED controller. Room for a few case fans, and fully compatible with radiators. Removable fan trays in the front and top of the chassis allow for additional space or mounting cooling outside of the chassis.
Corsair Crystal Series 570X RGB - mid tower - ATX
System cabinet
Mid tower
Red
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Top panel dust filter, front dust filter, rear dust filter, supports 120 mm radiator in rear, supports 120/240 mm radiator in top, RGB illumination, supports 120/240/280/360 mm radiator in front panel
No power supply
Specification Compliance
ATX
23.4 cm x 48 cm x 51.2 cm
10.9 kg
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Crystal Series...
