Corsair Crystal Series 570X RGB ATX Mid Tower Case - White
£171.21
29 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Four-panel tempered glass on every side of the case
  • Direct airflow path to keep your CPU and GPU running cooler
  • Room for practically anything
  • Cable management made simple
  • Case Form Factor: Mid tower
  • Motherboard Form Factor: ATX
  • Colour: White, White
  • Stock Status: In Stock
Product codes
With immaculate tempered glass enclosing the entire chassis, every component of your build is on display for all to see, including three vivid RGB LED fans and a built-in LED controller. Room for a few case fans, and fully compatible with radiators. Removable fan trays in the front and top of the chassis allow for additional space or mounting cooling outside of the chassis.
Product Description CORSAIR Crystal Series 570X RGB - mid tower - ATX
Product Type System cabinet
Form Factor Mid tower
Colour White
I/O Connectors 2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards ATX, microATX, Mini-ITX
System Cabinet Features Top panel dust filter, front dust filter, rear dust filter, supports 120 mm radiator in rear, supports 120/240 mm radiator in top, RGB illumination, supports 120/240/280/360 mm radiator in front panel
Power Device No power supply
Specification Compliance ATX
Dimensions (WxDxH) 23.4 cm x 48 cm x 51.2 cm
Weight 10.9 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Crystal Series...
£171.21
