Corsair CX650M CX Series 650W Semi Modular 80Plus Bronze ATX PSU
£77.44
Delivery:
Key features
  • 80 PLUS Bronze certified: high efficiency operation for less excess heat and lower operating costs
  • Thermally controlled fan: silent operation at low and medium loads
  • Semi -modular: make your builds and upgrades easy, with clean, great-looking results
  • Power Rating: 650Watt
Product codes
CX Series™ Modular power supply units are an excellent choice for basic system builds and desktop PC computer upgrades, offering high reliability, low noise, and easy installation. The flexible modular cabling system lets you use only the cables you need, and 80 PLUS Bronze certified efficiency means less excess heat, lower noise, and lower power bills. The large-diameter, thermally controlled fan makes the CX Series Modular quieter at idle, and reduces noise even when you’re pushing your system hard. The matte black finish, black-sleeved cables and black connectors help give your system a restrained, high-tech look.
Product Description CORSAIR CX-M Series CX650M - 2015 Edition - power supply - 650 Watt
Device Type Power supply - internal
Specification Compliance ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification 80 PLUS Bronze
Weight 3.27 kg
Localisation United Kingdom
Input Voltage AC 100-240 V
Output Voltage +3.3, +5, ±12 V
Power Capacity 650 Watt
Output connectors 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System 120 mm fan
Colour Matte black
Dimensions (WxDxH) 15 cm x 14 cm x 8.6 cm
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair CX650M CX Seri...
£77.44
