Corsair DDR4 2133MHz 8GB Module 1.2V Standard SO-DIMM
Product codes
This Corsair ValueSelect DDR4 SODIMM memory module is designed to guarantee maximum compatibility. It is assembled from select components and carefully screened for stable, reliable operation.
CORSAIR Value Select - DDR4 - 8 GB - SO-DIMM 260-pin - unbuffered
RAM memory
8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15 (15-15-15-36)
Unbuffered
Voltage
1.2 V
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair DDR4 2133MHz 8...
