Corsair Flash Voyager Mini USB 3.0 - 64GB
Key features
  • USB 3.0 performance
  • USB 2.0 compatibility
  • Compact size
  • Brushed metal housing
  • Key ring convenience
Product codes
The tiny USB flash drive with full-size USB 3.0 performance
Flash Voyager Mini USB 3.0 is the tiny USB flash drive with full-size USB 3.0 performance. The USB 3.0 connector allows for optimal file transfer speed with the latest systems, and it's fully compatible with USB 2.0. It comes with a detachable loop for attaching to your key ring, and the durable brushed metal housing resists wear and tear.
USB 3.0 performance
It's small, but it gives you full-size speed. Enjoy optimized performance when it's connected to a USB 3.0 port.
Its works with USB 2.0 ports, too.
Compact size
At just 1.25" (32mm) long, it goes almost anywhere and you won't think about it when you're not using it.
The sleek design protects your data and resists wear and tear. The logo is laser-etched, so it won't rub off.
The Mini comes with a rubber strap and metal loop for attaching to your key ring. You might never say "I left my USB flash drive at home" again.
USB 3.0 performance (compatible with USB 2.0)
Compact aluminium housing
Durable rubber strap and ring for convenient key-ring use
Limited 5 year warranty
Support for Microsoft Windows®, Mac OS X®, and Linux with no driver or software installation necessary
USB Standard-A connector works with both USB 3.0 and USB 2.0 ports
Product Description CORSAIR Flash Voyager Mini - USB flash drive - 64 GB
Product Type USB flash drive
Interface Type USB 3.0
Storage Capacity 64 GB
OS Required Linux, Apple MacOS X, Microsoft Windows
Manufacturer Warranty 5 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Flash Voyager...
