Corsair Gaming GLAIVE RGB Gaming Mouse Backlit RGB LED
£72.06
Delivery:
Key features
  • Contoured shape, designed for long gaming sessions
  • Custom, gaming grade native optical sensor
  • Interchangeable thumb grips provide a tailored fit
  • Onboard storage with hardware macro playback to take your gaming profiles with you
  • Surface calibration utility for maximizing precision and responsiveness
  • Dynamic, customizable multicolor backlighting
  • Aluminum scroll wheel with rubber grip ensures solid response and accuracy
Product codes
Corsair GLAIVE RGB is the ultimate gaming mouse in performance and comfort. The contoured shape is designed for extended play. A custom high-accuracy optical gaming sensor ensures maximum performance. Onboard profile storage saves lighting effects, macros and DPI settings for universal access to your settings on any PC. An aluminum scroll wheel with rubber grip guarantees solid response and accuracy.
Corsair Gaming GLAIVE RGB - mouse - USB - black
Mouse
Wired - USB
9.15 cm x 12.58 cm x 4.46 cm
122 g
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
16000 dpi
Performance
125/250/500/1000 reports per second, realtime sensitivity switching 100 - 16000 dpi
Polytetrafluoroethylene (PTFE) feet, built-in flash memory, braided cable, Corsair Utility Engine (CUE), 3-zone illumination, RGB LED backlight
Cable Length
1.8 m
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Gaming GLAIVE...
£72.06
