Corsair Gaming HS50 Stereo Green
£61.74
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Plush memory foam and swiveling earcups provide exceptional comfort for hours of gameplay
  • Legendary CORSAIR build quality and metal construction ensures long-term durability
  • Precision tuned 50mm neodymium speaker drivers bring superior sound quality with wide range and accuracy
  • Optimized unidirectional microphone reduces ambient noise for enhanced voice quality and is fully detachable for use on the go
  • Easy access on ear volume and mute controls for on-the-fly adjustments
  • Discord Certified for crystal clear communication and outstanding sound
  • Recommended Use: Computer, Game console, Portable electronics
  • Connectivity: Wired
  • Stock Status: In Stock
Product codes
The CORSAIR HS50 Stereo Gaming Headset provides comfort for hours of gameplay with its comfortable memory foam and swiveling earcups. Legendary CORSAIR build quality ensures long term durability and the precision tuned 50mm neodymium speaker drivers provide superior sound quality. The optimized unidirectional microphone reduces ambient noise for enhanced voice quality and is fully detachable for use on the go. Each ear cup features easy-access volume and mute controls allowing on the fly adjustments. The HS50 is Discord Certified for crystal clear communication and outstanding sound and is multi-platform compatible with PC, Xbox One, PS4, Nintendo Switch and mobile devices.
Product Description CORSAIR Gaming HS50 STEREO - headset
Product Type Headset - wired - 3.5 mm jack
Recommended Use Game console, portable electronics, computer
Localisation Europe
Colour Green
Headphones Form Factor Full size
Connectivity Technology Wired
Sound Output Mode Stereo
Audio Specifications Frequency Response 20 - 20000 Hz - Sensitivity 111 dB
Impedance 32 Ohm
Microphone Boom
Microphone Operation Mode Uni-directional
Controls Volume, microphone on/mute
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Gaming HS50 St...
£61.74
