Corsair Gaming M65 PRO RGB FPS Gaming Mouse Black 12000DPI O...
Corsair Gaming M65 PRO RGB FPS Gaming Mouse  Black 12000DPI Optical
£54.98
18 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 12000 DPI high-accuracy sensor
  • Aircraft-grade aluminum structure
  • Advanced weight tuning system
  • Extra-large PTFE glide pads
  • Surface calibration tuning utility
  • Harness the Power of CUE
  • Eight strategically placed buttons
  • High-mass scroll wheel
  • High-capacity Omron switches
  • Optimized sniper button positioning
  • Recommended Use: Gaming
  • Type: Mouse
  • Wired / Wireless: Wired
  • Colour: Black
  • Compatibility: PC
Product codes
The M65 PRO RGB features a 12000 DPI optical sensor that provides pixel-precise tracking and advanced surface calibration support. The aircraft-grade aluminum frame gives it low weight, and at the same time, extremely high durability. Use the advanced weight tuning system to set the center of gravity to match your play style, and harness the power of CUE for advanced button configuration, macro programming, and three-zone RGB backlighting customization.
Product Description CORSAIR Gaming M65 PRO RGB FPS - mouse - USB - black
Device Type Mouse
Connectivity Technology Wired - USB
Colour Black
Dimensions (WxDxH) 7.2 cm x 11.8 cm x 3.9 cm
Weight 115 g
Localisation Europe
Movement Detection Technology Optical
Buttons Qty 8
Movement Resolution 12000 dpi
Performance 125/250/500/1000 reports per second, realtime sensitivity switching 100 - 12000 dpi
Features Programmable buttons, adjustable weight, polytetrafluoroethylene (PTFE) feet, on-the-fly DPI switching, sniper button, braided cable, rubberised scroll wheel, aluminium body, OMRON switches, Corsair Utility Engine (CUE), 3-zone illumination
Cable Length 1.8 m
OS Required Microsoft Windows 7 / 8 / 10
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Gaming M65 PRO...
£54.98
