Corsair Gaming MM400 High Speed Gaming Mouse Pad
£27.61
Delivery:
Key features
  • Low-friction, high-performance mouse mat
  • Optimized for gaming sensors
  • Type: Mouse Pad
Product codes
The surface of the MM400 is made of a high-quality, long-lifespan polymer. It's tuned to deliver outstanding glide characteristics without sacrificing control, allowing for both consistent snap targeting and pixel-precise shots. The tuned micro-texture surface is optimized for gaming sensors, so you get a better glide feel without sacrificing control or accuracy.
The CGMM400 is stable and secure. You can't afford to have your mouse surface move in the middle of a firefight, so Corsair added a non-slip base that provides cushion with just the right amount of give. And it's made of natural rubber, so it doesn't have a harsh chemical odor.
Product Description CORSAIR Gaming MM400 Standard Edition - mouse pad
Product Type Mouse pad
Product Material Plastic, rubber
Dimensions (WxDxH) 35.2 cm x 27.2 cm
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Gaming MM400 H...
£27.61
