Corsair Gaming Sabre RGB 10000 DPI Lightweight Optical Gaming...
Corsair Gaming Sabre RGB 10000 DPI Lightweight Optical Gaming Mouse
£46.32
Delivery:
Key features
  • Four-zone color backlighting
  • 6,400 DPI optical sensor and multi-color DPI indicator
  • One weapon for any battle
  • Ultra light weight for faster play
  • Braided easy-flex USB cable
  • DPI selector with multi-color indicator
  • 1,000 Hz USB refresh rate
  • Recommended Use: Gaming
  • Type: Mouse
  • Wired / Wireless: Wired
  • Colour: [N/A]
  • Compatibility: PC
Product codes
The Corsair Gaming Sabre RGB is a light weight performance gaming mouse with four-zone 16.8Million color backlighting. If you like playing at lower DPIs and taking advantage of a larger mouse mat, you’ll be able to react quicker and you’ll have less fatigue over long playing sessions. The high-performance switches are custom designed for the fast response that gaming domination requires, and the 10000 DPI optical sensor is paired with instant DPI selection with a multicolor indicator so you’re always in control. It’s easy to customize the eight buttons to your requirements with the CUE software, and the 1.8 meter braided easy-flex resists snagging for unencumbered play.
Light weight
Just 100g total weight. React more quickly and play longer with less fatigue.
10000 DPI optical sensor and multi-color DPI indicator
Confident, high-accuracy tracking makes every click count.
Four-zone 16.8 million color backlighting
Enjoy virtually infinite customization.
CUE software
Powerful and intuitive Corsair Utility Engine gives you performance tuning and customization control.
8 programmable buttons
Fully configurable layout for personalized play.
High-performance Omron switches rated for 20 million clicks
Custom designed for gaming, with fast response and high reliability.
Ergonomic design
Fits comfortably in your hand and supports multiple grip styles.
Lag-free responsiveness for fast play.
1.8 meters of unencumbered roaming.
Product Description CORSAIR Gaming Sabre RGB - mouse - USB
Device Type Mouse
Connectivity Technology Wired - USB
Dimensions (WxDxH) 8 cm x 12.4 cm x 3.8 cm
Weight 100 g
Localisation Europe
Movement Detection Technology Optical
Buttons Qty 8
Movement Resolution 10000 dpi
Performance Polling rate: 1000 Hz, realtime sensitivity switching 50 - 10000 dpi
Features Programmable buttons, polytetrafluoroethylene (PTFE) feet, built-in flash memory, braided cable, 4-zone illumination, 16.8 million multi-colour illumination, Corsair Utility Engine (CUE)
Cable Length 1.8 m
OS Required Microsoft Windows Vista / 7 / 8 / 10
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Gaming Sabre R...
£46.32
