Corsair Graphite 760T Windowed Full Tower Gaming Case (White)
Key features
  • Swing-out side panels
  • Ample cooling potential
  • A clever drive bay design that maximizes interior volume
  • Front I/O panel with USB 3.0 and USB 2.0 connectors
  • Dual LED front intake fans with dual-speed control
Product codes
The Graphite Series 760T full-tower PC case starts with a visually stunning design that's a match for its stunning performance potential.
The beauty begins on the outside with its sculpted shapes and ingenious, full windowed hinged side panels with flush-mount latches. The front panel has two massive 140 mm intake fans bathed in soft LED light, and there's a dual-speed fan selector for performance or silence. Inside, there's ample cooling potential, with eight fan mounting locations and room for multiple radiators for self-contained liquid CPU coolers, or even custom liquid cooling. And, clever touches like modular drive cages and laterally mounted SSD bays maximize interior volume to help your high-performance dreams come true.
CORSAIR Graphite Series 760T - full tower - XL-ATX
System cabinet
Full tower
Arctic white
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone , 2 x USB 2.0
Supported Motherboards
ATX, microATX, Mini-ITX, Extended ATX, XL-ATX
System Cabinet Features
Windowed side panel, screwless drive bays, fan speed controller, front dust filter, cable management holes, modular HDD brackets, screwless side panels, made of steel, supports 120 mm radiator in bottom, supports 120/140 mm radiator in rear, supports 240/280 mm radiator in front panel, supports 240/280/360 mm radiator in top
No power supply
Specification Compliance
ATX
24.6 cm x 56.8 cm x 56.4 cm
11.2 kg
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Graphite 760T...
