Corsair H75 Hydro Series High Performance Liquid CPU Cooler
Key features
  • Copper microfin cold plate
  • Dual high-torque 120 mm PWM fans
  • Broad Intel and AMD socket compatibility
  • High quality ceramic bearing pump
Product codes
Documents
Hydro Series H75 provides effective and efficient liquid CPU cooling in a compact size. The 120 mm radiator has a thickness of only 25 mm and is paired with standard diameter, kink-resistant tubing for compatibility with smaller cases and tighter spaces. The dual SP120L 120 mm fans support PWM motherboard fan headers, so your motherboard can automatically control fan speeds based on CPU temperature. The tool-free mounting system has broad Intel and AMD socket compatibility. A copper microfin cold plate and high-quality ceramic bearing pump help provide reliable, low-noise heat transfer away from your CPU. And, like all Hydro Series liquid CPU coolers, Hydro Series H75 is completely self-contained and never needs filling or maintenance.
  • 25mm thick radiator core (29mm including housing) for enhanced compatibility with small cases.
  • Copper microfin coldplate with high quality, quiet ceramic bearing pump.
  • Easy to use tool-free black nickel finish mounting brackets for modern CPUs.
  • Dual SP120L PWM fans for great performance and adjustable noise levels.
  • Radiator Dimensions: 120mm x 152mm x 29mm
  • Fan Dimensions: 120mm x 25mm (2)
  • Fan Speed: 2000 RPM (+/- 10%)
  • Air Flow: 54 CFM
  • Static Pressure: 2.8 mm-H2O
  • Noise Level: 31.4 dB(A)
CPU Compatibility
  • Intel LGA 1150
  • Intel LGA 1155
  • Intel LGA 1156
  • Intel LGA 1366
  • Intel LGA 2011
  • AMD AM2
  • AMD AM3
  • AMD FM1
  • AMD FM2
Box Contents
  • Corsair Hydro Series H75 Performance Liquid CPU Cooler
  • Mounting kit for all modern CPU sockets
  • Two SP120L PWM high performance fans
  • Fan and radiator mounting screws
  • Thermal compound (pre-applied)
  • Quick Start Guide
CORSAIR Hydro Series H75 Liquid CPU Cooler - processor liquid cooling system
Processor liquid cooling system
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket
Heatsink Material
Copper
Fans Qty
Dual
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Ceramic bearing
Rotation Speed
2000 rpm
Air Flow
54 cfm
Noise Level
31.4 dBA
Pulse-width modulation (PWM) support, tool free
5 years warranty
Resources
The following resources are available for the Corsair H75 Hydro Series High Performance Liquid CPU Cooler
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair H75 Hydro Seri...
