Corsair HD120 RGB LED Static Pressure Fan with Controller
Key features
  • Quiet performance, vivid illumination
  • Control your look - and your cool
Product codes
Corsair Air Series LED high airflow PC case fans combine efficient, low-noise airflow with striking LED lighting. The custom-molded blades are designed for high-volume air delivery with less noise and turbulence than typical case fans. They're translucent, with a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series AF fan models perform best in unrestricted spaces with at least 3 cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. They work equally well as unrestricted intake fans for areas like side panels or bottom intakes.
CORSAIR Air Series LED HD120 RGB High Performance - case fan
Case fan
Package Content
Mounting screws for case fans, 6-port RGB LED hub, fan RGB LED controller
White, blue, yellow, red, green, orange, violet
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
800-1725 rpm
Air Flow
54.4 cfm
Noise Level
18 - 30 dBA
Power Connector
4-pin fan connector
Pulse-width modulation (PWM) support, RGB LED x12
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair HD120 RGB LED...
