Corsair HX1200i High Performance Series 1200Wt 80 PLUS Platin...
Corsair HX1200i High Performance Series 1200Wt 80 PLUS Platinum PSU
£233.49
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Quiet, efficient operation
  • Corsair link digital for advanced monitoring and control
  • Easy installation
  • Power Rating: 1200Watt
  • Stock Status: In Stock
Product codes
HXi Series power supplies give you extremely tight voltage control, virtually silent operation, and a fully modular cable set. With all Japanese 105°C capacitors, they're a great choice for high performance PCs where reliability is essential. 80 PLUS Platinum efficiency reduces operating cost and excess heat, and together with Zero RPM Fan Mode technology, gives you virtually silent operation.
With Corsair Link Digital support, you can monitor power supply performance, toggle single rail or multi rail mode, and control fan speed directly from your desktop. And, the fully modular, low profile cable set makes builds and upgrades easy, with clean, great-looking results.
Product Description CORSAIR HXi Series HX1200i - power supply - 1200 Watt
Device Type Power supply - internal
Specification Compliance ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification 80 PLUS Platinum
Weight 3.592 kg
Localisation United Kingdom
Input Voltage AC 100-240 V
Output Voltage +3.3, +5, ±12 V
Power Capacity 1200 Watt
Output connectors 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 8 x 8 pin PCI Express power with detachable 2 pin section , 12 x 4 PIN internal power , 12 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector
Cooling System 140 mm fan
Dimensions (WxDxH) 15 cm x 20 cm x 8.6 cm
Manufacturer Warranty 10 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair HX1200i High P...
£233.49
