Corsair Hydro Series H100i v2 Extreme Performance Liquid CPU...
Corsair Hydro Series H100i v2 Extreme Performance Liquid CPU Cooler
Key features
  • Advanced PWM fans
  • Built-in Corsair Link for monitoring, customization, and control
  • High-performance CPU cooling made simple
Product codes
Hydro Series H100i v2 is an all-in-one liquid CPU cooler with a 240mm radiator and dual SP120L PWM fans for cooling that's far superior to stock CPU cooling fans. Liquid cooling simply works better than air cooling, and the self-contained design of the H100i v2 makes it easy for you to protect your valuable CPU.
The H100i v2 has Corsair Link built in. Just attach the included cable to a USB header on your motherboard and download the free Corsair Link software, and you can monitor CPU and coolant temperatures, adjust fan speeds, and customize the LED lighting directly from your desktop.
  • 240mm dual-fan radiator: More surface area for superior cooling performance.
  • Improved coldplate and pump design: Better efficiency gives you lower temperatures with less noise.
  • Advanced SP120L PWM fan design: Better high-static pressure air delivery and customizable speed.
  • Built-in Corsair Link: Monitor CPU and coolant temperature, adjust fan speed, and customize lighting directly from your desktop.
  • User replaceable inserts: Change the colour of your cooler to match your system with the user-replaceable inserts on the radiator and pump cap (Sold Separately).
Includes:
  • Corsair Hydro Series H100i v2 High Performance Liquid CPU Cooler
  • Mounting kit for all modern CPU sockets
  • Two SP120L High Torque 120mm fans
  • USB cable for Corsair Link Integration
  • Fan and radiator mounting screws
  • Thermal compound (pre-applied)
  • Quick Start Guide
CORSAIR Hydro Series H100i v2 Extreme Performance Liquid CPU Cooler - processor liquid cooling system
Processor liquid cooling system
Package Content
Thermal paste
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA2011-3 Socket, LGA1151 Socket
Heatsink Material
Aluminium with copper base
Fans Qty
Dual
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
2435 rpm
Air Flow
70.7 cfm
Noise Level
37.7 dBA
Pulse-width modulation (PWM) support
Corsair Link
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Hydro Series H...
