Corsair Hydro Series H110i Extreme Performance Liquid CPU Cooler
Key features
  • Radiator of 280 mm
  • Advanced PWM fans
  • Built-in Corsair Link
  • High-performance CPU cooling
Product codes
Hydro Series H110i is an all-in-one liquid CPU cooler with a 280mm radiator and dual SP140L PWM fans for cooling that’s far superior to stock CPU cooling fans. Liquid cooling simply works better than air cooling, and the self-contained design of the H110i makes it easy for you to protect your valuable CPU.
For efficient cooling, bigger is better – it’s simple physics. If your PC’s case can fit a 280mm radiator, Hydro Series H110i will give you better performance. It’s Corsair Link compatible, so you can customize cooling performance, monitor system temperature, and change the color of the RGB LED lighting.
  • Large 280mm radiator: More cooling capacity for cases which have 280mm radiator mounts.
  • Improved coldplate and pump design: Better efficiency gives you lower temperatures with less noise.
  • Advanced SP120L PWM fan design: Better high-static pressure air delivery and customizable speed.
  • Built-in Corsair Link: Monitor CPU and coolant temperature, adjust fan speed, and customize lighting directly from your desktop.
Includes:
  • Corsair Hydro Series H110i Extreme Performance Liquid CPU Cooler
  • Mounting kit for all modern CPU sockets
  • Two SP140L High Torque 140mm fans
  • USB cable for Corsair Link. Integration
  • Fan and radiator mounting screws
  • Thermal compound (pre-applied)
  • Quick Start Guide
CORSAIR Hydro Series H110i Extreme Performance Liquid CPU Cooler - processor liquid cooling system
Processor liquid cooling system
Package Content
Thermal paste
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA2011-3 Socket, LGA1151 Socket, Socket AM4
Heatsink Material
Aluminium with copper base
Fans Qty
Dual
Fan Diameter
140 mm
Fan Height
25 mm
Rotation Speed
2100 rpm
Air Flow
113 cfm
Noise Level
43 dB
Pulse-width modulation (PWM) support
Corsair Link
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Hydro Series H...
