Corsair Hydro Series H45 Performance Liquid CPU Cooler
£49.05
Delivery:
Key features
  • More surface area for superior cooling performance
  • Improved coldplate and pump design - better efficiency gives you lower temperatures with less noise
  • Easy mounting - quick and easy installation
  • Advanced PWM fan design - better high-static pressure air delivery and customizable speed
Product codes
The Hydro Series H45 makes your PC run cooler and quieter when you replace your CPU’s stock heatsink. The compact components and flexible tubing make the Hydro Series H45 easy to install even if you’re cramped for space. It allows you to improve your CPU’s cooling efficient even in the most compact cases – as long as your case has a 120mm fan mount near the CPU, the H45 will probably fit. The H45 comes pre-filled, and never needs priming.
Product Description CORSAIR Hydro Series H45 Performance Liquid CPU Cooler - processor liquid cooling system
Product Type Processor liquid cooling system
Package Content Mounting screws, thermal compound
Compatibility LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA2011-3 Socket, LGA1151 Socket
Fan Diameter 120 mm
Features Pulse-width modulation (PWM) support
Weight 796 g
Manufacturer Warranty 5 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Hydro Series H...
£49.05
