Corsair Hydro Series H50-1 CPU Water-Cooling Cooler (LGA1156...
Corsair Hydro Series H50-1 CPU Water-Cooling Cooler (LGA1156 Compatible)
Key features
  • Pre-filled, closed-loop system is easy to install
  • Copper CPU cooling plate for maximum cooling performance
  • Integrated pump and reservoir is sealed for zero maintenance and improved leakage protection
  • Large 120mm radiator for fast heat dispersion
  • High-efficiency, low-noise 120mm fan for drawing cool air across the radiator
Product codes
Documents
The Corsair Cooling Hydro Series H50 CPU cooler gives you the power of liquid cooling in a compact, easy-to-install package. You get superior cooling for higher overclocking performance without the complexity of traditional liquid-cooling systems.
Air-based CPU coolers simply aren't as efficient as water coolers, and can take up too much valuable space. The compact, closed-loop Hydro Series H50 takes your CPU's temperature to new lows and takes up less room doing it.
CORSAIR Hydro Series H50 High Performance Liquid CPU Cooler - processor liquid cooling system
Processor liquid cooling system
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3
Heatsink Material
Copper
Fan Diameter
120 mm
2 years warranty
Resources
The following resources are available for the Corsair Hydro Series H50-1 CPU Water-Cooling Cooler (LGA1156 Compatible)
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Hydro Series H...
