Compatible with 4th generation Intel® Core™ series processors
The easy performance upgrade for your Intel CPU Your PC will run cooler and quieter when you replace your CPU's standard heatsink with a Hydro Series H55. Installation is straightforward. If you can get to the back of your PC's motherboard, you can install an H55. All you'll need is a screwdriver. Great for smaller cases The compact components and flexible tubing make H55 easy to install even if you're cramped for space.
Product Features
Specs
The following resources are available for the Corsair Hydro Series H55 Quiet CPU Cooler
