Corsair Hydro Series H60 2013 High Performance Liquid CPU Cooler
Key features
  • Better cooling
  • Lower noise levels
  • Easy to install
Product codes
Documents
Compatible with 4th generation Intel® Core™ series processors
The Corsair Hydro Series H60 is a fantastic choice for cooling. With a micro-channel cold plate and a split-flow designed manifold, the H60 brings remarkable technologies to an affordable price point. If that weren't enough, the H60 also features a fan custom-designed to offer enhanced static pressure, which means better cooling.
Make the Move to Liquid
Upgrade from your stock CPU fan or bulky air cooler to the efficiency and simplicity of liquid CPU cooling. Enjoy better cooling performance and lower noise, and protect your investment in your CPU.
Advanced Fan Design
The included SP120L fan uses custom-engineered impellers for better static pressure to noise ratio, offering improved performance at lower noise levels.
  • New, improved SP120L fan offers lower noise and better performance
  • Improved micro-fin copper coldplate for superior heat dissipation
  • Low evaporation, large diameter tubing offers decreased resistance and improved flexibility
  • Pre-filled, never needs refilling
  • Easy install magnetic mounting bracket
  • Low-profile pump for easy installation and better airflow
  • Low-profile black aluminum heat exchanger
  • Intel® Mounting hardware for LGA 115x, 1366, and 2011
  • AMD® Mounting hardware for AM2, AM3, FM1, and FM2
Specs
  • Coldplate Material Copper Micro Fin
  • Tubing Material Wide Diameter Low Evaporation Rubber
  • Radiator Material Aluminum
  • Radiator Size 120mm x 152mm x 27mm
  • Fan(s) included (1) SP120L - 120mm x 25mm
  • Fan Max Speed 2000 RPM +/- 10%
  • Fan Airflow 54 CFM
  • Fan Static Pressure 2.36 mmH20
  • Fan Noise Level 30.85 dBA
  • Intel Mounting Hardware LGA 115x, 1366, 2011
  • AMD Mounting Hardware AM2, AM3, FM1, FM2
Product Description CORSAIR Hydro Series H60 High Performance Liquid CPU Cooler processor liquid cooling system
Product Type Processor liquid cooling system
Colour Black
Compatibility LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket FM1, Socket FM2, Socket AM4
Heatsink Material Copper with aluminium base
Fan Diameter 120 mm
Fan Height 25 mm
Rotation Speed 2000 rpm
Air Flow 54 cfm
Weight 570 g
Features Mounting magnet
Manufacturer Warranty 5-year warranty
Resources
The following resources are available for the Corsair Hydro Series H60 2013 High Performance Liquid CPU Cooler
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Hydro Series H...
