Corsair Hydro Series H80i v2 Extreme Performance Liquid CPU C...
Corsair Hydro Series H80i v2 Extreme Performance Liquid CPU Cooler
£100.02
31 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Extra-thick radiator
  • Customized cooling performance
  • Built-in Corsair Link
  • High-performance CPU cooling made simple
  • Type: Water Cooling
  • Stock Status: In Stock
Product codes
Hydro Series H80i v2 is an all-in-one liquid CPU cooler with an extra-thick 120mm radiator and dual SP120L PWM fans for cooling that’s far superior to stock CPU cooling fans. Liquid cooling simply works better than air cooling, and the selfcontained design of the H80i v2 makes it easy for you to protect your valuable CPU.
The H80i v2 has Corsair Link built in. Just attach the included cable to a USB header on your motherboard and download the free Corsair Link software, and you can monitor CPU and coolant temperatures, adjust fan speeds, and customize the LED lighting directly from your desktop.
  • Extra-thick 120mm radiator: A depth of 49mm provides more surface are for rapid cooling.
  • Improved coldplate and pump design: Better efficiency gives you lower temperatures with less noise.
  • Advanced SP120L PWM fan design: Better high-static pressure air delivery and customizable speed.
  • Built-in Corsair Link: Monitor CPU and coolant temperature, adjust fan speed, and customize lighting directly from your desktop.
  • User replaceable inserts: Change the color of your cooler to match your system with the user-replaceable inserts on the radiator and pump cap (Sold Separately).
Includes:
  • Corsair Hydro Series H80i v2 High Performance Liquid CPU Cooler
  • Mounting kit for all modern CPU sockets
  • Two SP120L High Torque 120mm fans
  • USB cable for Corsair Link. Integration
  • Fan and radiator mounting screws
  • Thermal compound (pre-applied)
  • Quick Start Guide
Product Description CORSAIR Hydro Series H80i v2 High Performance Liquid CPU Cooler processor liquid cooling system
Product Type Processor liquid cooling system
Compatibility LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA2011-3 Socket, LGA1151 Socket
Heatsink Material Aluminium with copper base
Fans Qty Dual
Fan Diameter 120 mm
Fan Height 25 mm
Rotation Speed 2435 rpm
Air Flow 70.7 cfm
Noise Level 37.7 dBA
Features Pulse-width modulation (PWM) support Corsair Link
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Hydro Series H...
£100.02
