Corsair Memory Special Edition White Graphite Series 600T Mid...
Corsair Memory Special Edition White Graphite Series 600T Mid-Tower Case
Key features
  • Building a great-looking, high performance system has never been easier
  • Mid-tower size, full-tower features
  • Features for builders
Product codes
Documents
Inside the streamlined design of the Graphite 600T is a wealth of functionality that makes your build easier and enhances your computing experience.
Building a clean-looking, well-cooled system is easier and faster than ever with our innovative cable routing design, tool-free drive bays, dual 200mm fans with integrated fan controller, and CPU backplate cutout. Fitting even the largest video cards is a breeze, literally, with the split hard-drive bay setup that allows direct airflow from the 200mm intake fan to reach your graphics card. Maintenance is simple and quick with externally accessible dust filters and quick-release door panels. The Special Edition White 600T offers a side panel with a user-swappable side window or mesh insert that can house up to four 120mm fans! The Corsair Graphite Series 600T is the gamer's dream case.
  • User-swappable side panel window or mesh insert housing up to four 120mm fans!
  • Easily accessible dust filters keep the cool air flowing over your valuable components.
  • Keep your system cool with the dual 200mm fans and rear 120mm fan.
  • Built-in compatibility for SSDs in the six hard drive bays gives you the flexibility you need.
  • Access your hardware faster than ever with easy side panel removal.
  • Install or upgrade your CPU heatsink quickly with the easy-access backplate cutout.
  • Optimize airflow and keep your system neat and tidy using the intelligent cable management system.
  • Front panel includes USB 3.0, USB 2.0, Headphone, Mic, and a four-channel fan controller.
  • Dimensions: 20" (H) x 23.3" (L) x 10.4" (W) / (507mm x 592mm x 265mm)
  • Material: Steel structure with molded ABS plastic accent pieces
  • Color: White with black accents
  • Model: CC600T
  • Drive Bays: (x4) 5.25" / (x6) 3.5"/2.5" Drive Caddies
  • Cooling: (x2) 200mm Fans w/White LEDs / (x1) 120mm Fan
  • Expansion Slots: 8
  • Motherboard: ATX, mATX
  • Front Panel I/O: (x4) USB 2.0 / (x1) USB 3.0 / (x1) IEEE 1394 / (x1) Headphone, (x1) Mic/ 4-Channel Fan Controller
  • Power Supply: ATX (not included)
Product Description CORSAIR Graphite Series 600T - Special Edition - mid tower - extended ATX
Product Type System cabinet
Form Factor Mid tower
Colour White
I/O Connectors 4 x USB 2.0 , 1 x USB 3.0 , 1 x FireWire , 1 x headphones , 1 x microphone
Supported Motherboards ATX, microATX, Mini-ITX, Extended ATX
System Cabinet Features Fan speed controller, CPU cut-out
Power Device No power supply
Specification Compliance ATX
Dimensions (WxDxH) 26.5 cm x 59.2 cm x 50.7 cm
Weight 12.7 kg
Resources
The following resources are available for the Corsair Memory Special Edition White Graphite Series 600T Mid-Tower Case
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Memory Special...
