Corsair ML120 LED ML Series 120mm Magnetic RPM Fan White
£19.90
Delivery:
Standard: 1-3 working days
Key features
  • Magnetic bearing
  • Custom rotor design
  • Extensive control range
Product codes
Corsair Air Series LED high airflow PC case fans combine efficient, low-noise airflow with striking LED lighting. The custom-molded blades are designed for high-volume air delivery with less noise and turbulence than typical case fans. They're translucent, with a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series AF fan models perform best in unrestricted spaces with at least 3 cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. They work equally well as unrestricted intake fans for areas like side panels or bottom intakes.
Corsair ML Series ML120 PRO LED Premium Magnetic Levitation - case fan
Case fan
Package Content
Mounting screws for case fans
White
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Magnetic bearing
Rotation Speed
400-2400 rpm
Air Flow
12-75 cfm
Noise Level
16 - 37 dBA
Power Connector
4-pin fan connector
White LEDs, Pulse-width modulation (PWM) support
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair ML120 LED ML S...
£19.90
