Corsair ML120 ML Series 120mm Magnetic RPM Fans 2 Pack
£23.78
18 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Magnetic bearing
  • Custom rotor design
  • Extensive control range
  • Type: Case Fan
  • Stock Status: In Stock
Product codes
Corsair is expanding its range of fans with the introduction of the ML series, an acronym that reveals the technological nature of the new series of magnetic levitation fans.
The Corsair ML fans provide quiet operation and excellent performance, thanks to magnetic levitation of the rotor and the owner of the design of the fan blades.
The innovative design is able to considerably increase both the static pressure and a flow of air, thanks to the very low friction of the magnetic levitation system.
Moreover, thanks to the 4-pin PWM connector is possible to adjust timely the fan rotation speed so as to manage the performance / noise ratio appropriately.
The PRO version includes in the package a set of silicone nose pads, interchangeable with optional sets of various colors (red, white and blue) that have the dual function to cancel the vibrations produced by the fan itself and beautify the fan, matching the color of nose pads to that of your system!
Finally, the LED version is equipped with 4 high-brightness LED inserted in the rotor of the fan, guaranteeing maximum brightness and uniform lighting along the translucent material blades.
Product Description CORSAIR ML Series ML120 PRO Premium Magnetic Levitation case fan
Product Type Case fan
Packaged Quantity 2 (specifications are for single item)
Package Content Mounting screws for case fans
Fan Diameter 120 mm
Fan Height 25 mm
Fan Bearing Magnetic bearing
Rotation Speed 400-2400 rpm
Air Flow 12-75 cfm
Noise Level 16 - 37 dBA
Power Connector 4-pin fan connector
Features Pulse-width modulation (PWM) support
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair ML120 ML Serie...
£23.78
