Corsair RM850i SERIES 850w 80+ Gold Modular PSU
£145.87
45 left in stock
Delivery:
Standard: 1-3 working days
Key features
  • Corsair Link Integration for monitoring performance and adjustment of fan speed and multi-rail/single rail mode
  • 80 PLUS Gold efficiency, delivering 90% energy efficiency at real world load conditions
  • ZeroRPM mode for fanless operation at low loads and outstanding noise reduction
  • 135mm thermally controlled fluid dynamic bearing fan spins up as needed
  • Fully modular cables for easy installation, less clutter, and helps maximize airflow through your computer's chassis
  • Engineered to meet maximum power output at a server-grade 50°C temperature rating
  • Fan self-test switch to determine fan functionality even before installation
  • Over-voltage protection, under-voltage protection, short circuit protection, over power protection, and over temperature protection provide maximum safety to your critical system components
  • Power Rating: 850Watt
  • Stock Status: Clearance
Product codes
Corsair RMi series power supplies give you extremely tight voltage control, quiet operation, Gold-certified efficiency, and a fully modular cable set. Built with all Japanese 105°C capacitors, they're a great choice for high performance PCs where reliability is essential. 80 PLUS Gold efficiency reduces operating cost and excess heat, and Zero RPM fan mode ensures virtual silence at low and medium loads. Corsair Link Digital makes it easy monitor power supply performance, toggle single rail or multi rail mode, and control fan speed directly from your desktop. And, the fully modular DC cables make builds and upgrades easy, with clean, great-looking results.
Product Description CORSAIR RMi Series RM850i - power supply - 850 Watt
Device Type Power supply - internal
Specification Compliance ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification 80 PLUS Gold
Weight 1.985 kg
Localisation United Kingdom
Input Voltage AC 100-240 V
Output Voltage +3.3, +5, ±12 V
Power Capacity 850 Watt
Output connectors 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 8 x 4 PIN internal power , 10 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector
Cooling System 135 mm fan
Included Accessories Cable ties, cable bag
Dimensions (WxDxH) 15 cm x 18 cm x 8.6 cm
Manufacturer Warranty 10 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair RM850i SERIES...
£145.87
