Corsair SP120 PWM Quiet Dual Pack 120mm Fan
Key features
  • Three colored rings
  • Mounting screws
  • Voltage step-down adapter for lower speed operation
Product codes
Cooling today's high-performance PCs is a complex task, and a single fan design can't meet every need. The fan you use to pull hot air out of your case might not be the best fan to mount flush against a heatsink or radiator.
Static pressure is the measure of how well a fan can push air in this type of highly restrictive environment, and this is where the SP120 excels. It's an ideal solution for radiator and heatsink use, as well as drive bay intakes, and other locations where you're mounting a fan directly adjacent to a heat source.
Product Description CORSAIR Air Series SP120 Quiet Edition High Static Pressure case fan
Product Type Case fan
Packaged Quantity 2 (specifications are for single item)
Package Content Mounting screws for case fans, 3 replaceable colour rings
Fan Diameter 120 mm
Fan Height 25 mm
Fan Bearing Hydraulic bearing
Rotation Speed 1450 rpm
Air Flow 37.85 cfm
Noise Level 23 dBA
Power Connector 4-pin fan connector
Features Pulse-width modulation (PWM) support, rubberised corners
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair SP120 PWM Quie...
