Corsair SP120 RGB LED Static Pressure Fan with Controller
Key features
  • High static pressure cooling with led illumination
  • Designed for restricted spaces
Product codes
Corsair Air Series LED high airflow PC case fans combine efficient, low-noise airflow with striking LED lighting. The custom-molded blades are designed for high-volume air delivery with less noise and turbulence than typical case fans. They're translucent, with a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series AF fan models perform best in unrestricted spaces with at least 3 cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. They work equally well as unrestricted intake fans for areas like side panels or bottom intakes.
Product Description CORSAIR Air Series LED SP120 RGB High Performance case fan
Product Type Case fan
Package Content Mounting screws for case fans, 6-port RGB LED hub, fan RGB LED controller
Colour White, blue, yellow, red, green, orange, violet
Fan Diameter 120 mm
Fan Height 25 mm
Fan Bearing Hydraulic bearing
Rotation Speed 1400 rpm
Air Flow 52 cfm
Noise Level 26 dBA
Power Connector 3-pin plug
Features Custom-molded fan blades, RGB LED x4
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair SP120 RGB LED...
