Corsair Vengeance 32GB (2 x 16Gb) DDR4 B Illuminated Memory K...
Corsair Vengeance 32GB (2 x 16Gb) DDR4 B Illuminated Memory Kit - Blue LED Lighting
Key features
  • Great looking, great overclocking memory
  • Optimized for compatibility with the CPUs and motherboards
  • Next-generation density for the ultimate power user
Product codes
Vengeance Low Profile heat spreaders have a reduced height of 1.03". They're designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or any other space-constrained application where you need high-performance memory but standard Vengeance modules might not fit.
CORSAIR Vengeance LED - DDR4 - 32 GB: 2 x 16 GB - DIMM 288-pin - unbuffered
RAM memory
32 GB: 2 x 16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3200 MHz (PC4-25600)
Latency Timings
CL16 (16-18-18-36)
Dual channel, Vengeance heatspreader, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), blue activity LED's, 10 Layers PCB heatspreader, unbuffered
Voltage
1.35 V
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Corsair Vengeance 32GB...
