Corsair Vengeance 64GB (4x16GB) DDR4 3600MHz CL18 DIMM Memory
Key features
  • Great looking, great overclocking memory
  • Optimized for compatibility with the CPUs and motherboards
  • Next-generation density for the ultimate power user
Product codes
Vengeance Low Profile heat spreaders have a reduced height of 1.03". They're designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or any other space-constrained application where you need high-performance memory but standard Vengeance modules might not fit.
CORSAIR Vengeance LPX - DDR4 - 64 GB: 4 x 16 GB - DIMM 288-pin - unbuffered
RAM memory
64 GB: 4 x 16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Bundled with
Vengeance Airflow
Data Integrity Check
Non-ECC
Speed
3600 MHz (PC4-28800)
Latency Timings
CL18 (18-19-19-39)
Dual channel, 8 Layers PCB heatspreader, quad channel, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), Vengeance LPX low profile heatspreader, Corsair Vengeance Airflow Fan, unbuffered
Voltage
1.35 V
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Vengeance 64GB...
