Corsair Vengeance LPX 16GB (2x8GB) DDR4 3000MHz DIMM 288-pin
£109.83
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Great looking, great overclocking memory
  • Optimized for compatibility with the CPUs and motherboards
  • Next-generation density for the ultimate power user
Product codes
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
CORSAIR Vengeance LPX - DDR4 - 16 GB: 2 x 8 GB - DIMM 288-pin - unbuffered
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3000 MHz (PC4-24000)
Latency Timings
CL15 (15-17-17-35)
Dual channel, 8 Layers PCB heatspreader, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), Vengeance LPX low profile heatspreader, unbuffered
Voltage
1.35 V
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Corsair Vengeance LPX...
£109.83
