Corsair Vengeance LPX 16GB 4x4GB DDR4 DIMM C14 Red
Key features
  • Great looking, great overclocking memory
  • Optimized for compatibility with the CPUs and motherboards
  • Next-generation density for the ultimate power user
Product codes
Vengeance LPX memory is designed for high-performance overclocking. The heatspreader is made of pure aluminum for faster heat dissipation, and the eight-layer PCB helps manage heat and provides superior overclocking headroom. Each IC is individually screened for performance potential.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards and offers higher frequencies, greater bandwidth, and lower power consumption than DDR3 modules. Vengeance LPX DDR4 modules are compatibility-tested across X99 Series motherboards for reliably fast performance. There's XMP 2.0 support for trouble-free automatic overclocking. And, they're available in multiple colors to match your motherboard, your components, or just your style.
Product Description CORSAIR Vengeance LPX - DDR4 - 16 GB: 4 x 4 GB - DIMM 288-pin - unbuffered
Product Type RAM memory
Capacity 16 GB: 4 x 4 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 2400 MHz (PC4-19200)
Latency Timings CL14 (14-16-16-31)
Features Black heatsink, dual channel, 8 Layers PCB heatspreader, Black PCB, quad channel, Vengeance red low profile heatspreader, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), Vengeance LPX low profile heatspreader, unbuffered
Voltage 1.2 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
