Corsair VS Series VS450 450W 240V PSU 120mm
Key features
  • Real power
  • Low noise, high efficiency
  • Sophisticated design
Product codes
The Corsair VS450 is a great choice if you're building a home or office system with lower power demands, but you still demand the compatibility and reliability that Corsair is known for.
Product Description CORSAIR VS Series VS450 - power supply - 450 Watt
Device Type Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance ATX12V 2.3/ EPS12V
80 PLUS Certification 80 PLUS
Weight 1.5 kg
Localisation United Kingdom
Input Voltage AC 200-240 V
Output Voltage +3.3, +5, ±12 V
Power Capacity 450 Watt
Output connectors 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V , 2 x 6 pin PCI Express power , 4 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 2 x 4 PIN mini-power connector
Cooling System 120 mm fan
Included Accessories Cable ties, mounting kit
Colour Black powder coat
Dimensions (WxDxH) 15 cm x 14 cm x 8.6 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
