We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Marketing description is not available.
Product Description | Crucial - DDR4 - module - 128 GB - LRDIMM 288-pin - 2933 MHz / PC4-23400 - 3DS Load-Reduced | Product Type | Memory module | Capacity | 128 GB | Memory Type | DDR4 SDRAM - LRDIMM 288-pin | Upgrade Type | Generic | Data Integrity Check | ECC | Speed | 2933 MHz (PC4-23400) | Latency Timings | CL24 | Features | Octal rank, 3DS Load-Reduced | Voltage | 1.2 V | Manufacturer Warranty | Limited lifetime warranty (Germany - 10 years) |
General | |
Capacity | 128 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR4 SDRAM |
Form Factor | LRDIMM 288-pin |
Chips Organization | X4 |
Voltage | 1.2 V |
Expansion / Connectivity | |
Compatible Slots | 1 x memory - DIMM 240-pin |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Germany - 10 years) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
