Crucial 16GB (2x8GB) DDR2-667 1.8V FB-DIMM Memory
£570.60
Delivery:
Product codes
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
240-pin fully buffered DIMMs (FBDIMMs) are used to provide DDR2 SDRAM memory for servers and motherboards that use FBDIMM technology, as opposed to conventional registered DIMM (RDIMM) technology. DDR2 is a leading-edge generation of memory with an improved architecture that allows it to transmit data very fast. FBDIMM technology utilizes an advanced memory buffer that allows modules to be connected in series — meaning that more memory modules can be connected (and thus memory density is increased) and errors at the connection points are reduced.
Crucial - DDR2 - 16 GB: 2 x 8 GB - FB-DIMM 240-pin - Fully Buffered
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR2 SDRAM - FB-DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Fully Buffered
Voltage
1.8 V
DELL A2257246, HP 413015-B21, DELL A2257216, Kingston KFJ-BX667K2/16G, Kingston KTD-WS667/16G, Kingston KTH-XW667/16G, Kingston KTL-TSD10K2/16G, Kingston KTS-M3000K4/16G, Kingston KTS-M5000K8/16G, Kingston KVR667D2D4F5K2/16G, DELL A2257217, DELL A2257245, Sun SEWX2C1Z, Fujitsu S26361-F3263-L525, DELL A1787400, DELL A2257247
ASUS DSEB-DG, DSEB-DG/SAS; Intel Server Board S5400SF; SUPERMICRO X7DWA-N, X7DWE, X7DWN+, X7DWT, X7DWT-INF, X7DWT-INF+, X7DWU, X7QC3, X7QCE; Tyan Tempest i5400PL S5393, S5393G2NR, S5393WG2NR; i5400PW S5397AG2NRF, S5397WAG2NRF; i5400XL S5392ANR; i5400XT S5396A2NR, S5396A2NRF, S5396WA2NR, S5396WA2NRF
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial 16GB (2x8GB) D...
£570.60
