Crucial 16GB DDR3L PC3L 12800 1600MHz SODIMM Single Module
£150.00
Delivery:
Product codes
Notebook modules that operates at speeds up to 1600 MT/s and has a CL11 latency. It is dual voltage and can operate at 1.35V or 1.5V. It is Unbuffered and is non-ECC. It conforms to the industry standard SODIMM layout of 204 pins and is compatible with computers that take DDR3 SODIMM memory.
To use DDR3 memory, your system must have both a 204-pin SODIMM slot and a chipset that supports DDR3 memory. A DDR3 SODIMM will not fit into DDR2 or DDR memory sockets.
SODIMMs are smaller and thinner than regular DIMMs, and the 204-pin SODIMM PCBs are always ~2.6 inches long and are usually around 1.18 inches high (though the heights can vary slightly). They consist of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The number of memory components on a 204-pin SODIMM's printed circuit board (PCB) can vary, but the PCB will always have 102 pins on the front and the back both, for a total of 204 pins. The gold pins on the bottom of the SODIMM provide the connection between the memory module and the memory socket.
Product Description Crucial - DDR3 - 16 GB - SO-DIMM 204-pin - unbuffered
Product Type RAM memory
Capacity 16 GB
Memory Type DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 1600 MHz (PC3-12800)
Latency Timings CL11
Features Low Voltage, unbuffered
Voltage 1.35 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Crucial 16GB DDR3L PC3...
£150.00
