There's an easy cure for a slow computer: more memory. Designed to help your system run faster and smoother, Crucial Desktop Memory is one of the easiest and most affordable ways to improve your system's performance. Load programs faster. Increase responsiveness. Run data-intensive applications with ease, and increase your desktop's multitasking capabilities.
Product Description | Crucial - DDR4 - module - 16 GB - DIMM 288-pin - 3200 MHz / PC4-25600 - unbuffered | Product Type | Memory module | Capacity | 16 GB | Memory Type | DDR4 SDRAM - DIMM 288-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 3200 MHz (PC4-25600) | Latency Timings | CL22 | Features | Unbuffered | Voltage | 1.2 V | Manufacturer Warranty | Limited lifetime warranty (Germany - 10 years) |
General | |
Capacity | 16 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR4 SDRAM |
Form Factor | DIMM 288-pin |
Voltage | 1.2 V |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Germany - 10 years) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
