Crucial 1GB 184pin DIMM PC3200 DDRRAM NP Unbuffered CL3.0
Product codes
Help your desktop perform at its best. Designed to help your desktop run faster and smoother, a Crucial memory upgrade is one of fastest, most affordable, and easiest ways to improve your system's performance. Crucial memory empowers your desktop to achieve faster application loading times, faster system responsiveness, and increased ability to multitask and handle data-intensive programs. What does this mean? Spend less time staring at loading screens and more time getting stuff done. Crucial desktop modules are rigorously tested at both the component and module levels to ensure that your memory meets the stringent compatibility and performance standards. Every module manufactured is inspected by the Systems Compatibility Group before it leaves the doors. At a fraction of the price of your desktop, an investment in Crucial memory helps your system get up to speed.
Crucial - DDR - 1 GB - DIMM 184-PIN - unbuffered
RAM memory
1 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
400 MHz (PC3200)
Latency Timings
CL3
Unbuffered
Voltage
2.6 V
Lead Plating
Gold
IBM 22P9272, HP DE468A, IBM 73P3223, HP DE468G, DELL A0388042, IBM 22P9274, IBM 33R4963, NEC PK-UG-ME011, DELL A0547734, DELL A0288600, DELL A0740413, DELL A0740372, DELL A0740408, DELL A0546961, DELL A0548449, DELL A0740381, DELL A0740385, DELL A0740386, DELL A0740389, DELL A0740390, DELL A0740397, DELL A0740400, DELL A0740404, DELL A0740416, DELL A0740419, DELL A0740420, DELL A0740421, DELL A0740429, DELL A0740433, DELL A0740448, DELL A0740456, DELL A0740460, HP 335700-005, HP 407311-001, HP 445716-885, DELL A2251711, Kingston D12864D30A, Kingston KFJ2847/1G, Kingston KTD8300/1G, Kingston KTH-D530/1G, Kingston KTM-M50/1G, Kingston KTM3219/1G, Kingston KTN-PM400/1G, Kingston KVR400X64C3A/1G, Crucial MT16VDDF12864AY-40BF1, Crucial MT16VDDT12864AY-40BF2, Fujitsu S26361-F2847-E114, Fujitsu S26361-F2847-E115, Fujitsu S26361-F2847-L114, Fujitsu S26361-F2847-L115, IBM 73P3224
ABIT SG-80; Gigabyte GA-8IPE1000-G
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial 1GB 184pin DIM...
