Crucial 1TB MX500 2.5" 7mm SATA 6Gb/s SSD
FREE DELIVERY
£105.40
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fly through everything you do
  • Store up more data
  • Enjoy high efficiency
  • Form Factor: 2.5"
  • Capacity: 1TB, 1TB
  • Interface: Serial ATA-600
  • Type: Internal hard drive
  • Stock Status: In Stock
Product codes
IT’S WORTH IT.
Every time you turn on your computer, you’re using your storage drive. It holds all your irreplaceable files and it loads and saves almost everything your system does. Join more and more people who are keeping their family videos, travel photos, music, and important documents on an SSD, and get the near-instant performance and lasting reliability that comes with solid state storage. Upgrade with the Crucial® MX500 SSD, a drive built on quality, speed, and security that’s all backed by helpful service and support. Even if you’ve never installed an SSD, don’t sweat it – our step-by-step guide walks you through the process to make installation easy. It’s worth it.
  • Start your system in seconds
  • Capacities up to 2TB
  • Easy installation
  • 5-year limited warranty
Start your system in seconds, load files almost instantly, and accelerate the most demanding applications with the Crucial MX500. Our Dynamic Write Acceleration technology uses an adaptable pool of high-speed, single-level cell flash memory to generate blistering speeds.
Store up to 2TB of data
Save massive amounts of photos, music, and videos comfortably and securely. With fast access to your media, creations, and designs, you’re ready to share at the speed of your life.
Enjoy the efficiency of next-gen Micron 3D NAND
Our cutting-edge components are engineered from start to finish for efficiency. As a result, the Crucial MX500 uses only a minimal amount of power and still delivers a high price-to-performance ratio – without needing a financing plan to pay for it. Experience a faster, cooler, and quieter computer in your home or business. You’ll wonder how you ever put up with a hard drive.
Upgrade with a drive you can count on
With thousands of hours of pre-release validation, dozens of SSD qualification tests, and a heritage of award-winning SSDs, the Crucial MX500 has been thoroughly tried, tested, and proven. Secure your most important files on a drive with established dependability and the advanced features MX-series SSD's are known for.
Install with confidence
For many people, opening a computer and transferring data seems terrifying. That’s why we’ve made it easy in the step-by-step Crucial SSD Install Guide. Check it out before you buy, then install your own SSD quickly with everything transferred over successfully and hassle-free.
Micron quality – a higher level of reliability.
As a brand of Micron, one of the largest flash storage manufacturers in the world, the Crucial MX500 is backed by the same quality and engineering innovation that has produced some of the world’s most advanced memory and storage technologies for more than 35 years. Split-second speeds, lasting reliability, and a decades-long legacy – upgrading with the Crucial MX500 gives you the best combination of quality, performance, and security. It’s worth it.
Product Description Crucial MX500 - solid state drive - 1 TB - SATA 6Gb/s
Type Solid state drive - internal
Capacity 1 TB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
Nand Flash Memory Type 3D triple-level cell (TLC)
Form Factor 2.5"
Interface SATA 6Gb/s
Features TRIM support, Error Correction Code (ECC), Adaptive Thermal Protection, Microsoft eDrive compatible, Redundant Array of Independent NAND, Multistep Data Integrity Algorithm, Active Garbage Collection, dynamic write acceleration, upgradable firmware, 3D NAND Technology, Device Sleep support, power loss data protection, S.M.A.R.T.
Data Transfer Rate 600 MBps
Dimensions (Wxdxh) 7 mm
Manufacturer Warranty 5 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial 1TB MX500 2.5"...
£105.40
