Crucial 2GB (2 x 1GB) 240-pin DIMM DDR2 800MHz / PC2-6400 CL6...
Crucial 2GB (2 x 1GB) 240-pin DIMM DDR2 800MHz / PC2-6400 CL6 (CT2KIT12864AA800)
Product codes
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
240-pin DIMMs are used to provide DDR2 SDRAM memory for desktop computers. DDR2 is a leading-edge generation of memory with an improved architecture that allows it to transmit data very fast.
Product Description Crucial - DDR2 - 2 GB: 2 x 1 GB - DIMM 240-pin - unbuffered
Product Type RAM memory
Capacity 2 GB: 2 x 1 GB
Memory Type DDR2 SDRAM - DIMM 240-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 800 MHz (PC2-6400)
Latency Timings CL6
Features Unbuffered
Voltage 1.8 V
OEM Manufacturer Equivalent Part Number DELL A0944600, DELL A0944559, DELL A0944553, DELL A3418659, DELL A3418660, DELL A3418661, DELL A3418662, DELL A3418664, DELL A3418665, DELL A0944556, DELL A0944563, DELL A0944567, DELL A0944578, DELL A0944589, DELL A0944591, DELL A0944604, DELL A0944605, DELL A1523761, Kingston KTD-PEM605/2G, Kingston KVR800D2N5K2/2G, Kingston KVR800D2N6K2/2G
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
