Crucial 2GB, 200-pin SODIMM, DDR2 PC2-6400
£27.64
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • The fast, easy way to improve your laptop's performance
  • Make everything on your computer faster
  • Multitask with ease
  • Extend battery life
  • Type: DDR2 SDRAM
  • Capacity: 2GB
  • Connection: SO-DIMM 200-pin
  • Speed: 800MHz
  • Data Integrity: Non-ECC
Product codes
A small outline dual inline memory module (SODIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). SODIMMs get their name because they are smaller and thinner than regular DIMMs. The gold pins on the bottom of the SODIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a SODIMM are not connected.
200-pin SODIMMs are used to provide DDR and DDR2 SDRAM memory for notebook computers. 200-pin SODIMMs are available in PC2700 DDR SDRAM, PC3200 DDR SDRAM, DDR2 PC2-6400 SDRAM, DDR2 PC2-5300 SDRAM, DDR2 PC2-4200 SDRAM and DDR2 PC2-3200 SDRAM. To use DDR or DDR2 memory, your system motherboard must have 200-pin SODIMM slots and a DDR- or DDR2-enabled chipset. A DDR or DDR2 SODIMM will not fit into a standard SDRAM SODIMM socket. (Information about which memory technology your system uses is included in the Crucial Memory Advisor™ tool.)
The number of black components on a 200-pin SODIMM can vary, but it always has 100 pins on the front and 100 pins on the back, for a total of 200. 200-pin SODIMMs are approximately 2.625 inches long and 1.25 inches high, though the heights can vary. Like 144-pin SODIMMs, 200-pin SODIMMs have one small notch within the row of pins; however, the notch on the 200-pin SODIMMs is closer to the left side of the module.
Product Description Crucial - DDR2 - 2 GB - SO-DIMM 200-pin - unbuffered
Product Type RAM memory
Capacity 2 GB
Memory Type DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 800 MHz (PC2-6400)
Latency Timings CL6
Features Unbuffered
Voltage 1.8 V
Designed For DFI AM300-BF, CA230-BF, CT930-b, G5C100-N; Intel Desktop Board D945GSEJT, MGM45RM, MGM45WU; J&W MINIX-780G-SP128MB; Jetway NF94-270-LF; MSI Fuzzy RS690T
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial 2GB, 200-pin S...
£27.64
