Crucial 2GB kit (1GBx2) DDR2 667MHz (PC2-5300) CL5 240pin
Product codes
Micron Technology is one of the world's leading providers of advanced semiconductor solutions. Micron's DRAM and Flash components are used in today's most advanced computing, networking, and communications products, including computers, workstations, servers, cell phones, wireless devices, digital cameras, and gaming systems. Micron's mission is to be the most efficient and innovative global provider of semiconductor solutions.
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
240-pin DIMMs are used to provide DDR2 SDRAM memory for desktop computers. DDR2 is a leading-edge generation of memory with an improved architecture that allows it to transmit data very fast.
Product Description Crucial - DDR2 - 2 GB: 2 x 1 GB - DIMM 240-pin - unbuffered
Product Type RAM memory
Capacity 2 GB: 2 x 1 GB
Memory Type DDR2 SDRAM - DIMM 240-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 667 MHz (PC2-5300)
Latency Timings CL5
Features Unbuffered
Voltage 1.8 V
OEM Manufacturer Equivalent Part Number Kingston KTA-G5533/2G, Kingston KTS-SESK2/2G, Kingston KTS5277K2/2G, Kingston KVR400D2N3K2/2G, Kingston KVR667D2N5K2/2G, Apple MA247G/A, Sun SESX2A2Z, Sun X4200AF, Sun X5278A-Z, Sun SESX2A1Z
Designed For ABIT AA8XE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial 2GB kit (1GBx2...
