Crucial 32GB Kit (16GBx2) DDR4 2400 MT/s (PC4-19200) CL17 DR...
Crucial 32GB Kit (16GBx2) DDR4 2400 MT/s (PC4-19200) CL17 DR x8 Unbu
£113.18
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • The fast, easy way to improve your desktop's performance
  • Make everything on your computer faster
  • Multitask with ease
  • Maximize the value of your system
  • Micron quality - a higher level of reliability
  • Type: DDR4 SDRAM
  • Capacity: 32GB
  • Connection: DIMM 288-pin
  • Speed: 2400MHz
  • Data Integrity: Non-ECC
Product codes
The fast, easy way to improve your desktop’s performance
There’s an easy cure for a slow computer: more memory. Designed to help your system run faster and smoother, Crucial Desktop Memory is one of the easiest and most affordable ways to improve your system’s performance. Load programs faster. Increase responsiveness. Run data-intensive applications with ease, and increase your desktop’s multitasking capabilities.
Improve your system's responsiveness, run apps faster and multitask with ease
Install with ease; no computer skills required. How-to guides available at Crucial
Compatibility assurance when using the Crucial System Scanner or Crucial Advisor Tool
Micron quality and reliability is backed by superior component and module level testing and 42 years of memory expertise
Product Description Crucial - DDR4 - kit - 32 GB: 2 x 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - unbuffered
Product Type Memory kit
Capacity 32 GB: 2 x 16 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 2400 MHz (PC4-19200)
Latency Timings CL17
Features Dual rank, dual channel, unbuffered
Voltage 1.2 V
Manufacturer Warranty Limited lifetime warranty (Germany - 10 years)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£113.18
