Crucial 32GB Kit (2x16GB) DDR4 2133 MT/s (PC4-2133) CL15 DR x...
Crucial 32GB Kit (2x16GB) DDR4 2133 MT/s (PC4-2133) CL15 DR x4 ECC Registered DIMM 288pin
Product codes
More speed. More bandwidth. More efficient. Next generation DDR4 memory is here.
Overcome one of your greatest server limitations: memory. From networking, cloud computing, and virtualization to HPC, Big Data and more, memory - dependent server applications require increasingly higher densities of memory and higher levels of performance than are attainable on current DDR3 technology. Enter Crucial DDR4 server memory.
This product is a 32GB Kit consisting of (2) 16GB DDR4 server modules that operates at speeds up to 2133 MT/s and has a CL15 latency. It is a Registerred DIMM (RDIMM) with Error Correction Code (ECC). It conforms to the industry standard DDR4 RDIMM layout of 288 pins and is compatible with systems that take DDR4 2133MT/s RDIMM memory.
Crucial - DDR4 - 32 GB: 2 x 16 GB - DIMM 288-pin - registered
RAM memory
32 GB: 2 x 16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Dual rank, registered
Voltage
1.2 V
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial 32GB Kit (2x16...
