Crucial 4GB (2x2GB) DDR2-800 1.8V DIMM Memory
£50.24
11 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Selection – comprehensive product portfolio includes modules for over 50,000 systems and includes everything from the latest energy-efficient DDR3 modules to legacy DDR modules in a range of densities
  • Quality – all DRAM fully tested at the component and module level for performance, durability, and system compatibility
  • Reliability – backed by a limited lifetime warranty and over 30 years of DRAM industry experience
  • Compatibility – OEM-compatible
  • Type: DDR2 SDRAM
  • Capacity: 4GB
  • Connection: DIMM 240-pin
  • Speed: 800MHz
  • Data Integrity: Non-ECC
Product codes
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
240-pin DIMMs are used to provide DDR2 SDRAM memory for desktop computers. DDR2 is a leading-edge generation of memory with an improved architecture that allows it to transmit data very fast.
Each 240-pin DIMM provides a 64-bit data path (72-bit for ECC or registered or Fully Buffered modules). (The Ballistix™ and Ballistix Tracer™ high-performance memory do not come in 72-bit or registered modules.)
Standard DDR2 240-pin DIMMs are available in DDR2 PC2-3200 SDRAM, DDR2 PC2-4200 SDRAM, DDR2 PC2-5300 SDRAM, and PC2-6400 SDRAM.
To use DDR2 memory, your system motherboard must have 240-pin DIMM slots and a DDR2-enabled chipset. A DDR2 SDRAM DIMM will not fit into a standard SDRAM DIMM socket or a DDR DIMM socket.
The number of black components on a 240-pin DIMM can vary, but it always has 120 pins on the front and 120 pins on the back, for a total of 240. 240-pin DIMMs are approximately 5.25 inches long and 1.18 inches high, though the heights can vary. While 240-pin DDR2 DIMMs, 184-pin DDR DIMMs, and 168-pin DIMMs are approximately the same size, 240-pin DIMMs and 184-pin DIMMs have only one notch within the row of pins. The notch in a 240-pin DDR2 DIMM is closer toward the center of the module.
Our high-performance Ballistix 240-pin DIMMs come in DDR2 PC2-5300 SDRAM, DDR2 PC2-6400 SDRAM, and DDR2 PC2-8000 SDRAM. The Ballistix Tracer illuminated, activity-indicating high-performance 240-pin DIMM comes in SDRAM, DDR2 PC2-6400 SDRAM, and DDR2 PC2-8000 SDRAM
Product Description Crucial - DDR2 - kit - 4 GB: 2 x 2 GB - DIMM 240-pin - unbuffered
Product Type Memory kit
Capacity 4 GB: 2 x 2 GB
Memory Type DDR2 SDRAM - DIMM 240-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 800 MHz (PC2-6400)
Latency Timings CL6
Features Unbuffered
Voltage 1.8 V
OEM Manufacturer Equivalent Part Number IBM 46C7571, HP 501158-001, IBM 40W2991, IBM 46C7568, IBM 46M3065, Kingston KTD-PEM605/4G, Kingston KTH-BL495K2/4G, Kingston KTM5780ALP/4G, Kingston KVR800D2N5K2/4G, Kingston KVR800D2N6K2/4G
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial 4GB (2x2GB) DD...
£50.24
