Crucial 4GB DDR3 1600 MT/s (PC3-12800) CL11 SODIMM 204pin 1.
£24.85
45 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Selection – comprehensive product portfolio includes modules for over 50,000 systems and includes everything from the latest energy-efficient DDR3 modules to legacy DDR modules in a range of densities
  • Quality – all DRAM fully tested at the component and module level for performance, durability, and system compatibility
  • Reliability – backed by a limited lifetime warranty and over 30 years of DRAM industry experience
  • Compatibility – OEM-compatible
Product codes
Help your laptop perform at its best. Designed to help your laptop run faster and smoother, a Crucial memory upgrade is one of fastest, most affordable, and easiest ways to improve your system's performance. Crucial memory empowers your laptop to achieve faster application loading times, faster system responsiveness, and increased ability to multitask and handle data-intensive programs. What does this mean? Spend less time staring at loading screens and more time getting stuff done. Crucial laptop modules are rigorously tested at both the component and module levels to ensure that your memory meets the stringent compatibility and performance standards. Every module Crucial manufactures is inspected by the Systems Compatibility Group before it leaves the doors. At a fraction of the price of your laptop, an investment in Crucial memory helps your system get up to speed.
Crucial - DDR3L - 4 GB - SO-DIMM 204-pin - unbuffered
RAM memory
4 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Unbuffered
Voltage
1.35 V
Lead Plating
Gold
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial 4GB DDR3 1600...
£24.85
