Crucial 4GBKIT (2 x 2GB) 240-Pin DDR2 667MHz PC2-5300 NON ECC...
Crucial 4GBKIT (2 x 2GB) 240-Pin DDR2 667MHz PC2-5300 NON ECC CL5
£51.34
Delivery:
  • Type: DDR2 SDRAM
  • Capacity: 4GB
  • Connection: DIMM 240-pin
  • Speed: 667MHz
  • Data Integrity: Non-ECC
Product codes
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
240-pin DIMMs are used to provide DDR2 SDRAM memory for desktop computers. DDR2 is a leading-edge generation of memory with an improved architecture that allows it to transmit data very fast.
Product Description Crucial - DDR2 - 4 GB: 2 x 2 GB - DIMM 240-pin - unbuffered
Product Type RAM memory
Capacity 4 GB: 2 x 2 GB
Memory Type DDR2 SDRAM - DIMM 240-pin
Upgrade Type System specific
Data Integrity Check Non-ECC
Speed 667 MHz (PC2-5300)
Latency Timings CL5
Features Unbuffered
Voltage 1.8 V
OEM Manufacturer Equivalent Part Number Sun SESX2B3Z, Sun T6340-X-22, IBM 8233, Sun SESX2B2Z, Sun X4203AF, Sun X5279A-Z, Sun SESX2B1Z, Kingston KTA-G5533/4G, Kingston KTM-JS22K2/4G, Kingston KTS-SESK2/4G, Kingston KTS-SESVK2/4G, Kingston KTS5277K2/4G, Kingston KVR400D2N3K2/4G, Kingston KVR667D2N5K2/4G, Apple MA248G/A
Designed For Intel Desktop Board D955XBK
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial 4GBKIT (2 x 2G...
£51.34
