Crucial 8GB (2 x 4GB) DDR3 1066MHz PC3-8500 204pin SODIMM CL7...
Crucial 8GB (2 x 4GB) DDR3 1066MHz PC3-8500 204pin SODIMM CL7 Mac
£76.11
30 in stock
Delivery:
Standard: 1-3 working days
Product codes
Crucial Apple Equivalent 8GB (2 x 4GB Kit) PC3-8500 DDR3 SODIMM
Engineered to be compatible with your Apple® system, Crucial® Memory for Mac takes the guesswork out of a memory upgrade. Since Apple systems often have very specific memory requirements, including particular component densities, speeds, and SPD programming specifications, it's important to buy your memory from people who know Apple computers inside and out. With over a decade of experience manufacturing and developing memory for Apple systems, Crucial make it easy to find memory that's been designed specifically for your system.
  • Increases system performance
  • Compatible with Mac systems
  • Every single module extensively tested at the component and module level for functionality
  • Meets or exceeds Apple's own quality requirements
  • Easy installation
  • DDR3 modules include lead and halogen-free technology
  • Limited lifetime warranty
  • Technology DDR3 SDRAM
  • Memory Speed 1066 MHz ( PC3-8500 )
  • Form Factor SO DIMM 204-pin
  • CAS Latency CL=7
  • Supply Voltage 1.5 V
  • Manufacturer Warranty Limited lifetime warranty*
Reliability for Mac systems
If you're an Apple computer user, you probably expect intuitive, reliable performance from your system. Crucial think memory should work the same way, too. For each module Crucial manufacture, they send it through a rigorous testing process to ensure that you're getting a reliable, high-performance memory solution. Every module that leaves Crucial doors has been extensively tested at the component level for voltage and temperature resistances, signal integrity, and software compatibility. Even better, Crucial modules are lead and halogen-free*. The result? Reliable memory that meets or exceeds Apple's own memory requirements.
  • DDR3 modules only
  • Limited lifetime warranty valid everywhere except Germany. In Germany, warranty is limited to ten years from date of purchase.
Support for Mac systems
Unsure how to install memory or have an important question about your Apple system? Let Crucial's team of experts help! With a tech-savvy team that's well-versed in Apple systems, Crucial will provide the technical support you need - no matter how old your Mac computer gets. From phone support, videos, FAQ articles, and do-it-yourself guides, Crucial have got the resources you need to keep your system up to speed.
Crucial - quality you can depend on
Crucial is a trusted name when it comes to DRAM, and that's no coincidence. As a brand of Micron, one of the largest manufacturers of DRAM in the world, Crucial work with their engineers to design, refine, test, manufacture, and support their extensive line of memory modules. With a product portfolio that includes more than 250,000 different DRAM upgrades for more than 50,000 systems, Crucial have got one specifically designed for your Mac system. For more than a decade Crucial have kept Mac computer owners happy with high-performance memory and outstanding customer service. No matter what type of Mac system you have, Crucial have got a compatible solution.
Crucial - DDR3 - 8 GB: 2 x 4 GB - SO-DIMM 204-pin - unbuffered
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1066 MHz (PC3-8500)
Latency Timings
CL7
Unbuffered
Voltage
1.5 V
Apple iMac (Early 2009, Late 2009, Mid 2009); Mac mini (Early 2009, Late 2009, Mid 2010); MacBook (Late 2008)
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial 8GB (2 x 4GB)...
£76.11
